Surface Rt updates and App store
Ok i don't know if anybody remembers this but about a month ago or so there was somebody that posted a link to download and install 2 updates that was supposed to fix the problem with the Surface RT updating and installing app's from the windows app store, i still have the updates and if possible will post them ware everybody can download them and install then or just try to find a link it fixed mine great mne downloads updates and i just downloaded and installed the latest roll up update the other day with no problem so if i can do this i will post both updates they will fix your Surface RT tablet they fixed mine.
Was this discussion helpful?
You cannot post/share/distribute Microsoft software. Read the license. It is not
legal to redistribute.
they are updates everybody is trying to find Microsoft isn't helping somebody needs to and in doing it on a microsoft website for microsoft products  how is that Illegal. And its not software its and update for software that is needed.
If you post actual Microsoft software files for download on any site, including OneDrive, Dropbox, etc., Windows Update files included, you will likely be banned from this Forum.
well i never got to do it anyway i did offer but the website would not allow me to do it so nothing was ever done anyway i gave up trying . And besides that post was back in March im having more problems now and what i was going to post doesn't even work right now on my surface im sorry i ever bought the tablet.
Do you know why the app store on the surface 2 doesn't work??? And is there a way to fix it??
No im afraid i do not i am having my own trouble with the windows app store on my surface rt tablet and i can't figure this one out as of yet.
it tells me to get a new version of the app store but nothing comes up what about you what's your problem
There was a post on here with 3 updates to install and instructions on the proper order to install them if i find that i will post a link for you i did this and it fixed my surface i have the start bar back and i can access my windows store and download apps now so be patient.
Ok follow this link scroll down til you find the article ware there are 3 updates and instructions on how to install them i did this and it fixed my surface rt tablet everything works fine now thanks to this so follow the instructions word for word exactly as it describes and you will fix your surface ok now here is the link to the article on this forum.
https://answers.microsoft.com/en-us/surface/forum/surfwinrt-surfupdate/surface-rt/615f2d5b-ceca-4c28-b801-74f10d544499
thank you so much I got it to work now I appreciate the help
Last updated April 5, 2021 Views 1,645 Applies to:
