using wildcard in VLOOKUP table_array
I am plum googled out.  I have a worksheet where I need to find if values from one column exist in a range in another worksheet using VLOOKUP.  The table_array has some values that contain wildcards.  I cannot figure out how to get this to work.
EX (sorry I couldn't get the table to post right)
lookup value table_array col 1 table_array col 2
ab1234 ab* ok
x456 cbrt123 ok
cbrt123 cbrt7000 ok
cbrt7000 mod ok
mod x* ok
ab7890
ab9876
x5677
x1234145
I need the result to show that 'ab1234', 'ab7890', 'ab9876', 'x5677' and 'x1234145' exist in the table_array because it is matching to "ab*" or 'x*'.  I found many examples where the wildcard is in the lookup value, but none where the wildcard is in the table_array.  Anyone know how to do this?
Try this formula in cell B2 and copy down
=IFERROR(LOOKUP(2,1/SEARCH($F$2:$F$6,A2),$G$2:$G$6),"check")
table_array col1 and table_array col 2 is in F2:G6.
Hope this helps.
Ashish Mathur
www.ashishmathur.com
https://www.linkedin.com/in/excelenthusiasts/
Maybe this can help.
Ashish Mathur
Kind regards,
JP Ronse
If this response answers your question then please mark as Answer.
Last updated January 6, 2025 Views 1,482 Applies to:
