how to fix Intel(R) Management engine interface code 10 error
Device manager reports a code 10 error for IME device. Gigabyte Z68XP-UD5. I already tried to install new driver, Didn't work.. Reinstalling didn't work either.
Have you made any changes to your computer?
Method 1:
The Code 10 error code is generated when Device Manager has insufficient information or the error that is bubbled up by the device drivers is not recognized by Device Manager. Additionally, this error may occur when one of the drivers that the device needs does not start. If many drivers are being used by a particular device, it can be difficult to determine the one that failed.
Description of Code 10-related errors that Device Manager generates in Windows-based computers
http://support.microsoft.com/kb/943104
Method 2:
I would suggest you to run the fix it tool and check.
Hardware devices are not working or are not detected in Windows FIX IT:
http://support.microsoft.com/mats/hardware_device_problems
Method 3:
I would also suggest you to update the drivers and check.
Update driver for hardware that isn't working properly:
http://windows.microsoft.com/en-us/windows7/Update-a-driver-for-hardware-that-isnt-working-properly
What to do when a device isn't installed properly:
http://windows.microsoft.com/en-US/windows7/What-to-do-when-a-device-isnt-installed-properly
I would also suggest you to contact the manufacture of the computer and check.
79 people were helped by this reply
Last updated October 26, 2020 Views 43,713 Applies to:
