Volume Mixer does not retain settings for individual applications.
Original Title: <Sound settings aren't saving on application close>
After the latest patch Tuesday, I've noticed that sound settings aren't saving the way they used to.  Before, when I adjusted an individual sound for an application, and then closed the application, the sound was set to the same level when I restarted the application.  That is no longer happening.  Is there something I'm missing that I need to fix to get the sound settings to stick?
Previously, when I set the sound level for an application, it stayed after I quit the application, and restarted it.  Even through reboots.
But now, if I set a application's sound level to, say, 10, and later quit the application, when I restart it, it's back up at 100.
I want my sound settings to save again.
When you performed system restore, did everything work as expected?
I would suggest you to system restore to go back to before the updates were installed.
System Restore
http://windows.microsoft.com/en-US/windows7/products/features/system-restore
Then if the problem isn’t present, then install the updates from Windows Update one at a time to try to identify which is causing this problem to occur.
Last updated September 7, 2021 Views 9,894 Applies to:
