Sound coming from Laptop and not TV when connected to HDMI
I have Windows 10 and an Alienware laptop. When connecting the HDMI cable to my Sanyo TV the image is displayed flawlessly but Audio still plays through my laptop speakers. I have tried to switch the playback device to the HDMI but it is not available for selection. I have had this problem for months and am severely frustrated because I feel it should be an easy fix. Any help is extremely appreciated. Thank you!
Hello AKennedy,
Thank you for visiting Microsoft Community and providing us with the detailed description about the issue.
As per the description, I understand that you are experiencing issue with sound coming from laptop and not TV when connected to HDMI.
I certainly understand your concern and will try my best to help you.
I would suggest you to try the following methods and check if that helps.
Method 1:
  1. If you want your sound to work through a HDMI cable you will first have to adjust some settings in Windows 10.
  2. Press and hold the button “Windows” and the button “X”.
  3. Left click or tap on the “Control Panel” feature you have on the screen.
  4. Now in the “Control Panel” window you will need to left click or tap on the “Hardware and Sound” feature.
  5. Under the topic “Sound” you will have to left click or tap on the “Manage audio devices”.
  6. You will have in front of you a “Sound” window.
  7. Left click or tap on the “Playback” tab situated in the upper side of the window.
  8. After you selected the “Playback” tab you will need to left click or tap on the “Digital Output Device (HDMI)” feature.
  9. After left clicking or tapping the feature above you will see a check mark next to it thus making this option as default for the Windows 10 device.
  10. Now Left click on the “OK” button.
  11. Close the opened windows.
  12. Reboot the Windows 10 device.
  13. Open the Windows 10 device and check to see if your sound is working on the HDMI cable.
If the issue persists, follow method 2
Method 2:
  1. Left click or tap on the “Desktop” feature in the start screen of the Windows 8 or Windows 10 system.
  2. After you selected your Desktop feature you need to press and hold on the button “Windows” and on the button “X”.
  3. Left click or tap on the “Device Manager” feature.
  4. You will need to double click (left click) on the sound driver situated on the left side in the window.
  5. You will need to right click the sound device and left click on the “Update driver software” feature.
  6. You will get a window in which you need to left click or tap on the “OK” button.
  7. Reboot the Windows 10 device.
  8. After the Windows 10 reboots your device should have the latest drivers installed.
  9. Check now and see if your sound works through a HDMI cable to the TV.
If the issue persists, follow method 3
Method 3:
I would suggest you to refer to the suggestions provided by “Nirmal S” replied on November 1, 2012 in the Microsoft Community link given below and check if that helps.
http://answers.microsoft.com/en-us/windows/forum/windows_8-hardware/i-have-no-sound-on-the-tv-connected-through-an/d912f036-c321-4948-b30c-11fecdf62ef3
I hope this information is helpful.
Please do let us know if you need any further assistance, we will be glad to assist you.
Last updated September 20, 2020 Views 9,770 Applies to:
