Realtek Audio Console does not work anymore
Greetings,
After a recent windows update, I don't know exactly which one, Realtek Audio Console stopped working, it takes about one minute loading, than a message is displayed "Cannot connect to RPC service." I'm currently unable to configure some sound features like 5.1 and 7.1 sound.
My computer also had another audio control software installed, called Nahimic, but I have removed it, because I don't use it anymore, since it not always work properly.
I've also tried the steps from another thread "Realtek Audio Console not opening. Gives error "Cannot connect to RPC service.", the software worked until I restarted my PC, and does not work anymore.
I hope someone can help have this problem sorted out.
Daniel Almeida
Hello Daniel_Almeida92, my name is Farah and I'm an Independent Adviser. I can help you regarding this problem
What is your mother board, or laptop model is it's a laptop?
This issue occur when you install the wrong driver. Provide me with the right model and I'll find the suitable one for you
Feel free to ask back any questions and let us know how it goes. I will keep working with you until it's resolved
Cheers!
Farah
Yes
No
Thank you for your quick reply F.Farah,
I've solved the issue, by performing these steps:
- Unistalling the previous version of Realtek Audio drivers in Control Panel -> Programs and Features
- Restart
- Installing the Realtek Audio drivers from the manufacturer (MSI)
- Restart
- Uninstalling both Nahimic and Realtek Audio Console (Win+X > Apps and Features > select the App > click the "Unistall" button)
- Installing Nahimic and Realtek Audio Console from "Microsoft Store", by opening the link indicated in the manufacturer's website
This should've solve the issue, but I had another problem, and the issue persisted, so I've followed this thread written in pt-BR:
"Realtek Áudio Console não pode se conectar ao serviço RPC."
I've disabled Realtek HD Audio Universal Service in task manager, to improve startup time, and I had to enable it again, Task Manager > Startup > right-click on "Realtek HD Audio Universal Service" > Enable, followed by another restart. Now both Nahimic and Realtek Audio Console are working.
Yes
No
Great! If you need any help, let me know
Have a great holidays.
Yes
No
Thanks. Nice Holidays.
Yes
No
Hii,
Can u help me with this I want to install Realtek Audio Control from microsoft store but unable to download it. Can u please help me. My Motherboard Model Gigabyte A320M S2H and its Desktop. Please reply me as soon as possible.
Yes
No
i have the same problem when i open realtek audio control it says cannot connect to rpc service . i uninstall it and tried to install it again ftom store it says error like you have, any one can help us?
Yes
No
Bro.... I solved  my problem. If u give me ur email then i can help you. I will send the file☺.
Yes
No
Hi
Reinstalled the drivers.
Deleted everything realtek related in the registry.
reinstalled realtek. Updated driver.
Updated windows.
Nothing works to open realtek manager.
Yes
No
I installed it. If u also want then send me ur email id I will send you the driver and the manager file and installation process.☺
Yes
No
My email is , *** Email address is removed for privacy ***
Tell me if you need something else and thank you so much.
Yes
No
Last updated September 6, 2021 Views 13,486 Applies to:
