May 10, 2024
Contribute to the Windows forum!
Click here to learn more 💡
May 10, 2024
Windows 10 Forum Top Contributors:
Ramesh Srinivasan - neilpzz - Volume Z - franco d'esaro - _AW_ ✅
Problems with display quality
I use windows 10 with a gforce gts 250 and 2 samsung hd monitors (S24D340).
I have one of the monitors connect with hdmi, and the other with vga.
Suddenly when i was in the middle of writing in word, the graphics on the screen became verry bad.
It looks like all the graphics (text, images and video) has lower resolution and if i see a circle i can see the pixels (its not a smooth circle).
I have tried to reinstall the drivers, i have gone through the monitor calibration and the cleartype with no results.
There was no changes made when this happened. The problem is also on both my user accounts on this computer.
Hi Tore,
Thank you for posting on Microsoft Community.
We appreciate your interest in Windows 10.
Is your graphics driver updated?
Method 1: Uninstall and reinstall graphics drivers.
Step 1: Open Run command by pressing Windows key + R and type appwiz.cpl in the box.
Step 2: Select your graphics driver and Click on Uninstall/Change button.
Step 3: Reinstall the graphics driver.
Refer to the following article on Download and install drivers
http://answers.microsoft.com/en-us/insider/wiki/insider_wintp-insider_devices/how-to-install-and-update-drivers-in-windows-10/a97bbbd1-9973-4d66-9a5b-291300006293
If the issue still persist, follow the method below and check if the issue is resolved.
Method 2: Compatibility mode.
Below link is an article on Make older programs compatible with this version of Windows (Applies to Windows 10 also):
http://windows.microsoft.com/en-us/windows-8/older-programs-compatible-version-windows
If the issue is not resolved, follow the method below and check if the issue is resolved.
Method 3: Troubleshoot video card problems:
Below link is an article on Troubleshoot video card problems (Applies to Windows 10 also):
http://windows.microsoft.com/en-in/windows-8/find-install-display-drivers
Hope this helps!
Get back to us if you have queries regarding Windows, we will be happy to help you.
Thank you,
Thank you for you reply, sadly none og steps above solved my problem.
I think that the problem might be related to color (32bit/16bit etc) But the settings says that i am using 32bit.
This image is the windows 10 background.
Last updated April 15, 2023 Views 680 Applies to:
