No sound after using headphones
The answer for me was as simple as clicking the speaker icon on the tool bar. Clicking the "advanced" button. Which opened the "Advanced Controls for Volume" menu. Then un-checking the box that said, "1 PC Spk Mute" under "Other Controls." I wouldn't have tried this except for the first answer in this forum lead me to believe that it could be software. Thank you.
So YES, some computers DO have a software control that turns the speakers off while allowing the headphones to still function.
·Was this reply helpful?
Unplug the headphones - Right Click the little speaker on lower right next to clock -
PlayBack Devices - right click inside the blank/white box - check both boxes Show
Disabled and Show Disconnected - highlight the Speaker - Properties - Device
Usage - Use this Device - check the other tabs as needed.
Hope this helps.
Rob Brown - MS MVP - Windows Desktop Experience : Bicycle - Mark Twain said it right.
Microsoft MVP Windows and Devices for IT 2009 - 2020
30 people found this reply helpful
Last updated January 17, 2024 Views 26,608 Applies to:
