Ian, to be sure: does the third monitor only display half the screen at all times, as shown in your screenshot?
Have you experimented with the cabling to see if you can narrow the issue down to the cable or port being used? Can you replicate the issue with the third screen on any other cable or port? Have you tried changing cables and ports?
If none of the steps I already gave work to fix that, then The Display driver is so important here that merely updating it is sometimes not enough. So let's try everything possible to get it working correctly:
First make sure you have updated the Display driver from the PC or Display adapter maker's Support Downloads web page for your exact model number, HP Serial Number or Dell Service Tag - from the sticker on the PC.
If necessary first remove the old driver using DDU
https://www.wagnardsoft.com/content/ddu-guide-t... (not necessary with Microsoft Basic driver which is a placeholder if nothing else is available) and/or installing in Safe Mode with Networking (so you have internet), or Safe Mode, accessed by one of these methods:
https://www.digitalcitizen.life/4-ways-boot-saf...
While there check also for newer chipset, BIOS/UEFI firmware (very important), network, sound, USB3 and other drivers, comparing to the ones presently installed in Device Manager reached by right clicking the Start Menu.
If this doesn't give you the latest or ideal driver for what you need, compare it to the driver offered by the Intel driver update Utility here:
http://www.intel.com/content/www/us/en/support/...
or the Nvidia Update utility here:
http://www.nvidia.com/Download/Scan.aspx?lang=e...
or the AMD autodect utility here:
http://support.amd.com/us/gpudownload/windows/P...
For Display issues one fix that is working is to Roll back or Uninstall the Driver on the Display Device > Driver tab, restart PC to reinstall driver.
You can also try older drivers in Device Manager > Display device > Driver tab > Update Driver > Browse > Let Me Pick.
Then you will know you've tried everything in addition to Windows Update drivers.
Adjust the screen resolution until it fits and looks best at Settings > System > Display. Set different resolutions for multi-monitors here:
https://www.addictivetips.com/windows-tips/diff...
Check for a monitor drivers by expediting Windows Updates (including Optional Updates) in Settings > Update & Security > Windows Update > Check for Updates to install all Updates until no more are offered.
