I need help fixing my WIFI
My WIFI keeps disconnecting every 5 mins and I need to disable and reenable my wifi adapter every time this happens, when The wifi is gone I can't find another Wifi network, My adapter info is:
Manufacturer: Realtek Semiconductor Corp.
Description: Realtek 8852CE WiFi 6E PCI-E NIC
Driver version: 6001.16.126.323
Physical address (MAC): FA-C5-27-71-25-5E
what Can I do??
My laptop is Lenovo legion 5 16IRX9 i9-14500hx RTX 4060
I tried the usual like updatinf or uninstalling and reinstalling the update, power management solution WLan configure and all the rest
Hi Orwa,
It sounds like the issue might be related to the WiFi 6E function of your adapter. One solution you could try is disabling the 6E capability to see if the connection becomes more stable.
To do this, press Windows + X > Device Manager and locate your Realtek 8852CE adapter. Right-click the adapter, select Properties, and then go to the Advanced tab.
Look for a setting related to WiFi band or wireless mode (sometimes labeled as “Preferred Band” or “Wireless Mode”). If you find an option that lets you select a mode, change it to use WiFi 6 (5GHz) or even WiFi 5 instead of 6E, then apply the changes and restart your adapter.
Let me know if this works!
Francisco Montilla
Give back to the Community. Help the next person who has this issue by indicating if this reply solved your problem. Click "Yes" or "No" below.
Last updated March 26, 2025 Views 35 Applies to:
