How to change help settings when using Corel Draw 7
In windows 7. Pop up help screen. A real nusance
every time i try to use my corel draw 7 programme, a box windows help and support pops up. How do I stop it doing that, I dont need help and suppor, I know the programme very well
Just an idea
Is this Windows help & support window suggesting that you download the old hlp-format help program?
If so, it indicates that Corel Draw is trying to tell you something using its help system when it starts [it may well be generated by an error condition as Corel Draw 7 is not recognised as Windows 7 compatible] and Windows is then recognising that it would need to get this old hlp-format help system to be able to show you what the application is trying to tell you.
Allowing Windows to download & install this old help system would be the only way of getting rid of the popup.  And then you'd be able to see what Corel Draw was trying to tell you.
Try*3 - a user
Dell Inspirons 7779, 1545, 9300; Windows 10 Home x64 & Pro x86; Office Pro 2007; HP DJ2540; HTC UPlay [Android 6.0], MyPhoneExplorer
Last updated August 28, 2021 Views 3,080 Applies to:
