May 20, 2024
Microsoft Learn Q&A needs your feedback!
May 10, 2024
Contribute to the Windows forum!
Click here to learn more 💡
May 10, 2024
Windows 7 Top Forum Contributors:
Bill Smithers - LemP ✅
May 10, 2024
Windows 7 Forum Top Contributors:
Help: rating problem !!
Please I recently bought the windows 7 Ultimate.. I have problem in the rating, when it wants to finish rating it gives a message said that The experience couldn't be computed for your system, what I can do to fix it? here 's the log :
1593253 (2204) - winsat\logging.cpp:0815: --- START 2009\10\29 15:51:57 PM ---
1593253 (2204) - winsat\main.cpp:4301: Command Line = "C:\Windows\system32\winsat.exe" formal -cancelevent 067d3367-687d-48f4-84fa-0a00e1ada3e0
1593269 (2204) - winsat\processwinsaterror.cpp:0095: ERROR: tried to read resource strings, unknown exception occured
1593425 (2204) - winsat\main.cpp:4474: > IsFormal=TRUE IsMoobe=FALSE.
1593472 (2204) - winsat\main.cpp:4585: Watch dog system enabled
1593472 (2204) - winsat\main.cpp:4600: Main watch dog timer set to 600.0 seconds
1593987 (2204) - winsat\main.cpp:2490: > DWM Running.
1594361 (2204) - winsat\main.cpp:2497: > turning off DWM.
1594361 (2204) - winsat\main.cpp:2470: > EMD service will be restored on exit.
1595203 (2204) - winsat\syspowertools.cpp:0983: > Read the active power scheme as '381b4222-f694-41f0-9685-ff5bb260df2e'
1595203 (2204) - winsat\main.cpp:2793: > power policy saved.
1595484 (2204) - winsat\syspowertools.cpp:1015: > Set the active power scheme to 8c5e7fda-e8bf-4a96-9a85-a6e23a8c635c'
1595500 (2204) - winsat\main.cpp:2814: > power policy set to maximum.
1596373 (2204) - winsat\logging.cpp:1763: ERROR: pahse enter/leave imballance
1596373 (2204) - winsat\main.cpp:0948: > IsOfficial=TRUE IsFormal=TRUE IsMoobe=FALSE RanOverTs=FALSE RanOnbatteries=FALSE
1596373 (2204) - winsat\main.cpp:1775: > Run Assessment features
1596545 (2204) - winsat\main.cpp:1775: > Run Assessment dwm -aname DWM -time 10 -fbc 10 -disp off -normalw 12 -width 1280 -height 1024 -winwidth C(1144) -winheight C(915) -rendertotex 6 -rtdelta 3 -nolock
1603971 (2204) - winsat\main.cpp:1775: > Run Assessment d3d -aname Batch -time 5 -fbc 10 -disp off -animate 10 -width 1280 -height 1024 -totalobj 300 -batchcnt C(10) -objs C(26) -rendertotex 6 -rtdelta 3 -texpobj C(1)
1611053 (2204) - winsat\main.cpp:1775: > Run Assessment d3d -aname Alpha -time 5 -fbc 10 -disp off -animate 10 -width 1280 -height 1024 -totalobj 300 -batchcnt C(75) -objs C(26) -rendertotex 6 -rtdelta 3 -texpobj C(1)
1618011 (2204) - winsat\main.cpp:1775: > Run Assessment d3d -aname Tex -time 5 -fbc 10 -disp off -animate 10 -width 1280 -height 1024 -totalobj 500 -batchcnt C(125) -objs C(20) -noalpha -texshader -totaltex 10 -texpobj C(4) -rendertotex 6 -rtdelta 3
1625218 (2204) - winsat\main.cpp:1775: > Run Assessment d3d -aname ALU -time 5 -fbc 10 -disp off -animate 10 -width 1280 -height 1024 -totalobj 500 -batchcnt C(125) -objs C(20) -noalpha -alushader -totaltex 10 -texpobj C(1) -rendertotex 6 -rtdelta 3
1632519 (2204) - winsat\main.cpp:1775: > Run Assessment d3d -dx10 -aname Batch -time 5 -fbc 10 -disp off -animate 10 -width 1280 -height 1024 -totalobj 300 -batchcnt C(10) -objs C(26) -rendertotex 6 -rtdelta 3 -texpobj C(1)
1640022 (2204) - winsat\main.cpp:1775: > Run Assessment d3d -dx10 -aname Alpha -time 5 -fbc 10 -disp off -animate 10 -width 1280 -height 1024 -totalobj 300 -batchcnt C(75) -objs C(26) -rendertotex 6 -rtdelta 3 -texpobj C(1)
1647308 (2204) - winsat\main.cpp:1775: > Run Assessment d3d -dx10 -aname Tex -time 5 -fbc 10 -disp off -animate 10 -width 1280 -height 1024 -totalobj 500 -batchcnt C(125) -objs C(20) -noalpha -texshader -totaltex 10 -texpobj C(4) -rendertotex 6 -rtdelta 3
1654905 (2204) - winsat\main.cpp:1775: > Run Assessment d3d -dx10 -aname ALU -time 5 -fbc 10 -disp off -animate 10 -width 1280 -height 1024 -totalobj 500 -batchcnt C(125) -objs C(20) -noalpha -alushader -totaltex 10 -texpobj C(1) -rendertotex 6 -rtdelta 3
1662877 (2204) - winsat\main.cpp:1775: > Run Assessment d3d -dx10 -aname GeomF4 -time 7 -fbc 10 -disp off -animate 10 -width 1280 -height 1024 -totalobj 150;200;241 -batchcnt C(50);C(200);C(300) -objs C(12);C(26);C(45) -noalpha -geomf4shader -texpobj C(0) -rendertotex 6 -rtdelta 3 -tierframes 60 -tiertime 1
1672517 (2204) - winsat\main.cpp:1775: > Run Assessment d3d -dx10 -aname GeomV8 -time 7 -fbc 10 -disp off -animate 10 -width 1280 -height 1024 -totalobj 75;100;120 -batchcnt C(25);C(100);C(150) -objs C(8);C(17);C(29) -noalpha -geomv8shader -texpobj C(0) -rendertotex 6 -rtdelta 3 -tierframes 60 -tiertime 1
1681456 (2204) - winsat\main.cpp:1775: > Run Assessment d3d -dx10 -aname CBuffer -time 5 -fbc 10 -disp off -animate 10 -width 1280 -height 1024 -totalobj 75 -batchcnt C(25) -objs C(8) -rendertotex 6 -rtdelta 3 -texpobj C(1) -cbuffershader -cbufa 2 -cbuff 5 -cbufp 6
1688008 (2204) - winsat\main.cpp:1775: > Run Assessment mfmedia -input C:\Windows\Performance\WinSAT\winsat.wmv -nopmp
1690161 (2204) - winsat\main.cpp:1775: > Run Assessment mediaex -input C:\Windows\Performance\WinSAT\Clip_1080_5sec_MPEG2_HD_15mbps.mpg -dshow -video offscreen -audio mute -width 100%m -height 100%m -constrain -savereg -autoprofname -expfrmmin 270 -expfrmmax 300 -overrideframetype int2fps
1698336 (2204) - winsat\main.cpp:1775: > Run Assessment mediaex -input C:\Windows\Performance\WinSAT\Clip_1080_5sec_VC1_15mbps.wmv -video offscreen -audio mute -width 100%m -height 100%m -constrain -savereg -autoprofname -expfrmmin 135 -expfrmmax 150 -overrideframetype prog
1705387 (2204) - winsat\main.cpp:1775: > Run Assessment mediaex -input C:\Windows\Performance\WinSAT\Clip_480i_5sec_6mbps_new.mpg -dshow -video offscreen -audio mute -width 100%m -height 100%m -constrain -savereg -autoprofname -expfrmmin 270 -expfrmmax 300 -overrideframetype int2fps
1714918 (2204) - winsat\main.cpp:1775: > Run Assessment mediaex -input C:\Windows\Performance\WinSAT\Clip_480p_5sec_6mbps_new.mpg -dshow -video offscreen -audio mute -width 100%m -height 100%m -constrain -savereg -autoprofname -expfrmmin 135 -expfrmmax 150 -overrideframetype prog
1722719 (2204) - winsat\main.cpp:1775: > Run Assessment mediaex -input C:\Windows\Performance\WinSAT\Clip_1080_5sec_10mbps_h264.mp4 -video offscreen -audio mute -width 100%m -height 100%m -constrain -savereg -autoprofname -expfrmmin 135 -expfrmmax 150 -overrideframetype prog
1730129 (2204) - winsat\main.cpp:1775: > Run Assessment mediaex -input C:\Windows\Performance\WinSAT\Clip_480_5sec_6mbps_h264.mp4 -video offscreen -audio mute -width 100%m -height 100%m -constrain -savereg -autoprofname -expfrmmin 270 -expfrmmax 300 -overrideframetype int2fps
1737383 (2204) - winsat\main.cpp:1775: > Run Assessment media -input C:\Windows\Performance\WinSAT\winsatencode.wmv -encode C:\Windows\Performance\WinSAT\winsat.prx
1748006 (2204) - winsat\main.cpp:1775: > Run Assessment moobego
1748038 (2204) - winsat\main.cpp:1775: > Run Assessment cpu -encryption -up
1758162 (2204) - winsat\main.cpp:1775: > Run Assessment cpu -compression -up
1768333 (2204) - winsat\main.cpp:1775: > Run Assessment cpu -encryption2 -up
1778426 (2204) - winsat\main.cpp:1775: > Run Assessment cpu -compression2 -up
1788489 (2204) - winsat\main.cpp:1775: > Run Assessment cpu -encryption
1798707 (2204) - winsat\main.cpp:1775: > Run Assessment cpu -compression
1808940 (2204) - winsat\main.cpp:1775: > Run Assessment cpu -encryption2
1819236 (2204) - winsat\main.cpp:1775: > Run Assessment cpu -compression2
1829486 (2204) - winsat\main.cpp:1775: > Run Assessment mem
1834727 (2204) - winsat\main.cpp:1775: > Run Assessment disk -seq -read -n 0
1852153 (2204) - winsat\main.cpp:1775: > Run Assessment disk -ran -read -n 0
1867815 (2204) - winsat\main.cpp:1775: > Run Assessment disk -scen 2009 -drive C:
1955519 (2204) - winsat\processresults.cpp:0962: > Wrote cpu expression compression score to the registry 159
1955519 (2204) - winsat\processresults.cpp:1004: Total physical mem available to the OS : 1.99 GB (2,145,026,048 bytes)
1955519 (2204) - winsat\processresults.cpp:1086: Physical memory available to the OS is less than 3.0GB-64MB : limit mem score to 5.5
1955534 (2204) - winsat\processresults.cpp:1480: > Wrote disk score to the registry 550
1955550 (2204) - winsat\processresults.cpp:1498: > Wrote random read disk score to the registry 1433
1955612 (2204) - winsat\main.cpp:0948: > IsOfficial=TRUE IsFormal=TRUE IsMoobe=FALSE RanOverTs=FALSE RanOnbatteries=FALSE
1956767 (2204) - winsat\processresults.cpp:0962: > Wrote cpu expression compression score to the registry 159
1956767 (2204) - winsat\processresults.cpp:1004: Total physical mem available to the OS : 1.99 GB (2,145,026,048 bytes)
1956767 (2204) - winsat\processresults.cpp:1086: Physical memory available to the OS is less than 3.0GB-64MB : limit mem score to 5.5
1956829 (2204) - winsat\processresults.cpp:1480: > Wrote disk score to the registry 550
1956845 (2204) - winsat\processresults.cpp:1498: > Wrote random read disk score to the registry 1433
1956907 (2204) - winsat\main.cpp:4736: ERROR: Unable to save validated results.
1957079 (2204) - winsat\syspowertools.cpp:1015: > Set the active power scheme to 381b4222-f694-41f0-9685-ff5bb260df2e'
1957079 (2204) - winsat\main.cpp:2855: > Power state restored.
1957079 (2204) - winsat\main.cpp:2870: > Successfully reenabled EMD.
1957344 (2204) - winsat\watchdog.cpp:0311: Watch dog system shutdown
1957344 (2204) - winsat\main.cpp:4909: > exit value = 1.
2034736 (3068) - winsat\logging.cpp:0815: --- START 2009\10\29 15:59:18 PM ---
2034736 (3068) - winsat\main.cpp:4301: Command Line = "C:\Windows\system32\winsat.exe" formal -cancelevent 1eb8c3d6-4df0-4450-93c2-ef750d252889
2034752 (3068) - winsat\processwinsaterror.cpp:0095: ERROR: tried to read resource strings, unknown exception occured
2034923 (3068) - winsat\main.cpp:4474: > IsFormal=TRUE IsMoobe=FALSE.
2034970 (3068) - winsat\main.cpp:4585: Watch dog system enabled
2034970 (3068) - winsat\main.cpp:4600: Main watch dog timer set to 600.0 seconds
2035547 (3068) - winsat\main.cpp:2490: > DWM Running.
2035937 (3068) - winsat\main.cpp:2497: > turning off DWM.
2037014 (3068) - winsat\syspowertools.cpp:0983: > Read the active power scheme as '381b4222-f694-41f0-9685-ff5bb260df2e'
2037029 (3068) - winsat\main.cpp:2793: > power policy saved.
2037357 (3068) - winsat\syspowertools.cpp:1015: > Set the active power scheme to 8c5e7fda-e8bf-4a96-9a85-a6e23a8c635c'
2037357 (3068) - winsat\main.cpp:2814: > power policy set to maximum.
2037685 (3068) - winsat\logging.cpp:1763: ERROR: pahse enter/leave imballance
2037685 (3068) - winsat\main.cpp:0948: > IsOfficial=TRUE IsFormal=TRUE IsMoobe=FALSE RanOverTs=FALSE RanOnbatteries=FALSE
2037685 (3068) - winsat\main.cpp:1775: > Run Assessment features
2037872 (3068) - winsat\main.cpp:1775: > Run Assessment dwm -aname DWM -time 10 -fbc 10 -disp off -normalw 12 -width 1280 -height 1024 -winwidth C(1144) -winheight C(915) -rendertotex 6 -rtdelta 3 -nolock
2045563 (3068) - winsat\processresults.cpp:1480: > Wrote disk score to the registry 0
2045625 (3068) - winsat\main.cpp:0948: > IsOfficial=TRUE IsFormal=TRUE IsMoobe=FALSE RanOverTs=FALSE RanOnbatteries=FALSE
2046701 (3068) - winsat\processresults.cpp:0962: > Wrote cpu expression compression score to the registry 159
2046701 (3068) - winsat\processresults.cpp:1004: Total physical mem available to the OS : 1.99 GB (2,145,026,048 bytes)
2046701 (3068) - winsat\processresults.cpp:1086: Physical memory available to the OS is less than 3.0GB-64MB : limit mem score to 5.5
2046717 (3068) - winsat\processresults.cpp:1480: > Wrote disk score to the registry 550
2046733 (3068) - winsat\processresults.cpp:1498: > Wrote random read disk score to the registry 1433
2046764 (3068) - winsat\main.cpp:4736: ERROR: Unable to save validated results.
2046951 (3068) - winsat\syspowertools.cpp:1015: > Set the active power scheme to 381b4222-f694-41f0-9685-ff5bb260df2e'
2046951 (3068) - winsat\main.cpp:2855: > Power state restored.
2046951 (3068) - winsat\main.cpp:2873: > Not necessary to reenable EMD cache.
2047279 (3068) - winsat\watchdog.cpp:0311: Watch dog system shutdown
2047279 (3068) - winsat\main.cpp:4909: > exit value = 1.
Hi mtr2006,
Thank you for visiting Microsoft Answers.
Perform sfc scan and try using Rate this computer option.
System File Checker(sfc) scan will make Windows replace corrupt or missing system files on your computer.
Steps to perform sfc scan:
1. Click Start, click All Programs, click Accessories, right-click Command Prompt, and select “Run as Administrator”.
2. Click Continue or supply Administrator credentials if prompted.
3. In the Command Prompt window type the following, and press Enter: sfc /
For more information refer this link:
http://support.microsoft.com/kb/936212
If the above method didn’t help you in resolving your issue then try the below steps.
1. Upgrade BIOS to the latest version.
2.
Then login system as the administrator account, start Windows Explorer and locate the path to "C:\Windows\Performance\WinSAT\DataStore" and delete all the files from that folder. Restart the computer and re-rate this computer again.
Afzal-Microsoft Support.
Visit our Microsoft Answers Feedback Forum and let us know what you think.
· If the above method didn’t help you in resolving
· Perform sfc scan and try using Rate this
Last updated September 26, 2018 Views 6,212 Applies to:
