Facing problem while using Oppo Enco Buds
I have Oppo Enco Buds, it works perfectly fine on phone but on my P.C., it creates problem. If I pause the media and resume it after 10-20 seconds then the media buffers for the 5-10 seconds and then the Buds stop giving sound and after 30-40 seconds, it starts giving sound. Please help as I am a student, and it creates a problem for me while studying.
Hello, I'm Jan and I'm happy to help you today. Most likely the Bluetooth drivers or other issues are causing the problem. Please try one of the methods below to fix the Bluetooth audio issue.
1. Press Start
then search for "Devices"
select "Bluetooth and other device settings"
select your Bluetooth Oppo Enco Buds from the list
Click Remove device Click
Yes.
2. Open Device Manager
Click
"View" Tick "Show hidden devices"
Expand Bluetooth
Then right-click on your Bluetooth device
Then uninstall all the drivers related to your Bluetooth Oppo Enco Buds
Restart your computer.
Then try to pair again your Bluetooth device.
3. Open Control Panel
Click View by: Large Icons
Select Devices and printers right click on your Bluetooth Oppo Enco Buds from the
list of devices, then select properties, and click the service tab. then check all properties under Bluetooth services. Click apply and then OK.
4. Check if you have any restore points available and try to perform a system restore.
https://support.microsoft.com//windows/use-syst...
5. Ensure that the Computer or Laptop has the latest Bluetooth drivers. Download the latest drivers from the Computer/Laptop Manufacturer's support website. Install the driver and restart your computer.
6. Try to perform a clean. There might be other applications causing the delay or problem on your Bluetooth device.
How to perform a clean boot in Windows
https://support.microsoft.com//topic/how-to-per...
Hi, Jan I tried all this but still no improvement.
I apologize that those steps did not resolve the problem.
Maybe someone else in the community has a different suggestion.
Hello Harsh.
Try these fixes for Oppo Enco earbuds stop working in Windows:
https://www.digitaltrends.com/home-theater/comm...
https://www.asavvyweb.com/windows/how-to-fix-wi...
https://www.auslogics.com/en/articles/fix-no-so...
https://www.youtube.com/watch?v=tz9ViKUUZjA
Feel free to ask back any questions. If you'll post back detailed results then I may know what to suggest next, if necessary.
______________________________________________
Standard Disclaimer: There are links to non-Microsoft websites. The pages appear to be providing accurate, safe information. Watch out for ads on the sites that may advertise products frequently classified as a PUP (Potentially Unwanted Products). Thoroughly research any product advertised on the sites before you decide to download and install it.
Retired 2023, thirteen year daily forums volunteer, Windows MVP 2010-2020
Not working
Last updated April 18, 2025 Views 10,137 Applies to:
