Do Not Track setting in Edge
Microsoft made a step in the right direction for consumer privacy when IE had its Do Not Track feature set to ON by default. Why does the Edge browser reverse this trend?
Thank you for posting the query on Microsoft Community.
When the Send Do Not Track requests setting is turned on it will send a request to the websites you visit to not track your activities, including to the third parties whose content may be hosted on the sites you visit.
As you said it is turned off in Edge. We need to manually turn if ON.
To change this setting, go to More actions  > Settings, and under Advanced settings, select View advanced Settings, and then, under Privacy and services, turn the Send Do Not Track requests setting on or off
For additional information on Microsoft Edge, I suggest you to refer the link below:
http://windows.microsoft.com/en-US/windows-10/edge-privacy-faq
Hope it helps.
Thanks, but that doesn't explain why they are making their browser less private by default than before. It is definitely a step backwards. Last night I just reverted back to Windows 8 anyway. The privacy issues are a major concern.
Hope it helps.
Thank you for your answer; however, I cannot find
'More actions ..... Settings/Advanced Settings/View Advanced Settings/Privacy & Services and finally .... turn on 'Send Do Not Track Requests'
My left-hand choices File Explorer / Settings / Power  / Apps ...... clicking on Settings brings me to the page with many icons and I have gone through all of them to see if I can find where I need to be.
Can you further assist please ?
You may want to do some research.  I didn't dig to deep but this is what I found so far.
If the Do not Track or DNT is set by default or automatically then the site or advertiser can choose to completely ignore it.  The user has to specifically opt out.  I also read that this setting can be completely ignored as there is not legal obligation to implement the feature
Why in the world did you provide a detailed response while completely ignoring the actual question?
what? you contradicted yourself
Last updated May 20, 2021 Views 4,931 Applies to:
