Bluetooth shows error while enabling it's discoverability.
May 10, 2024
Click here to learn more 💡
May 10, 2024
Ramesh Srinivasan - neilpzz - Volume Z - franco d'esaro - _AW_ ✅
Hi Saumya,
Thank you for contacting Microsoft Community.
I suggest you to follow the below methods and check if it helps.
Method 1:I suggest you tocheck if the file history services are running or not, once I suggest you to stops and start the service. Follow as below and check if it helps.
1. Click Start, type services. MSc and hit Enter
2. Locate for Bluetooth services.
3. Right click on it and click properties.
4. Check whether the service is running, then click on “stop”.
5. Then again click on “start” and check.
Method 2: I suggest you to follow the below settings to unhide the device and check if it helps.
How to find Bluetooth settings in Windows 10:
Hope this information is helpful and do let us know if you need further assistance. We will be glad to assist.
·Was this reply helpful?
16 people found this reply helpful
Hi Saumya,
Thank you for posting your query on Microsoft Community.
I understand that you are facing issues with Windows 10. I apologize for the inconvenience caused to you.
The issue could occur if there is change in Bluetooth settings.
To assist you better, please provide us the below information:
Refer to the below methods and check if it helps.
Method 1: I suggest you to perform the Hardware and Devices troubleshooter. Check if it helps.
1. Click on search bar.
2. Type “Troubleshooting” without the quotes and click on Troubleshooting.
3. Click on View All on the left panel of the screen.
4. Click on Hardware and Devices.
5. Click on Next and follow the prompts to run the troubleshooter.
If the issue still persist, refer to the below method.
Method 2: I suggest you to update Bluetooth driver in the Device Manager and check it helps.
1. Press Windows Key + R Key.
2. Then type “devmgmt.msc” without the quotes and hit on
Enter Key.
3. Search for Bluetooth drivers.
4. Right click on the driver and click on Update driver software.
Reply to us with the information, so that we can assist you better.
Let us know if you need any further assistance on Windows related issues and we will be glad to help.
Okay, so I had this same problem, too. If all of the given ways above aren't working (just like what I did), you may use this way.
1. Open Start button
2. Look for Device Manager
3. Click for Bluetooth, then expand.
4. You may see "Mediatek Bluetooth Adaptor" (for my laptop) or any keyword that contains "Bluetooth Adaptor"
5. Right Click, then select "Uninstall".
6. Once uninstalled, the selection will refresh, then click "Scan for hardware changes"
7. The device is detected. It will show an exclamation mark above the device, thus, it will automatically reinstall.
8. If not automatically reinstalled, right click the device then select "Install hardware settings".
No need to tell my young age, but I'm always willing to help. Hope this would help you, Mr. Acharya, and to other users who are struggling with this problem.
49 people found this reply helpful
