Number of tile rows on Start Screen
Hi everybody,
This morning when I started my surface, I found 4 rows of tiles in my start screen. And I kinda liked it. But after flipping the screen from landscape to portrait then from portrait back to landscape, I found that my start screen has only 3 rows of tiles.
I looked around on the web, and there's no tool that allows to customize this number. Even using REGEDIT.
Does anyone have an idea how to change it. The 4 rows start screen is perferct for me.
Thanks in advance.
It should support 4 rows at 1366x768.  This chart's a good reference: http://www.eightforums.com/tutorials/2690-start-screen-metro-apps-change-number-rows-windows-8-a.html
Try setting the MonitorSize key indicated in this KB to a larger screen size:
Note that the Scaling registry key is not present by default, and will need to be created.
This didn't work. 😞
It should work - at least it does on my Surface.  Here is my exact reg value:
.reg begin -->
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Scaling]
"MonitorSize"="15.4"
<-- end
Reboot after adding the reg value.
One more thing - after doing this, flip to portrait mode, swipe Settings -> Tiles -> "Show more tiles" to enable a total of 9 rows in portrait.
Note that this only affects the modern ui; and, only scales to the minimum permittable font scaling for the actual resolution.
Last updated May 18, 2018 Views 7,139 Applies to:
