Wi-Fi connection control questions
Hi!
I have 2 question on Wi-Fi connection:
1. Is it possible for US version of Surface RT to use European Wi-Fi channels 12, 13, when I'm in Europe?
2. Is it possible to select exact Wi-Fi band to use (eg. n-only, bgn, bg, g-only)?
Greetings Eric,
Have you tried switching your router down to use Channel 11?
Thank you for posting,
Steven B
Hi all I had the same problem and changed the value of the channel from 12 to 6 in the wireless setting in my router and it worked fine
Now I can connect
Last updated October 23, 2020 Views 14,405 Applies to:
