limited wifi connectivity
I have intermittent limited connectivity showing up when I wake the RT. current fix is to disconnect and connect.  works but a bit annoying. I have a wireless N E4200, wpa psk2. all machines in the house work and do not have this problem.
Hello Ron,
At this time, we are investigating the cause of the Limited Connectivity on the Surface. The currently suggested work around is to drop their router to 802.11 B/G mix until we are able to fix the 802.11N problem.
Thank you for posting,
Steven B
Hi JHzz,
Have you tried turning off your 5GHz band on your router?
This seems to fix some intermittent connection issues.
You can also try turning off Wireless N completely and just using Wireless G.
This also seems to have an effect on connection issues.
Give that a try and let me know your results.
Derrek.
Last updated October 24, 2018 Views 25,439 Applies to:
