I just bought a Surface Pro 6 (i7-8650U - 16 GB RAM) and can't stream HDR content towards a 4k OLED LG monitor.
My monitor is capable of HDR, since I use it with my XBOX ONE X (the HDR icon correctly appears).
I have connected that monitor to my surface pro 6 (using the same Xbox one x cable and TV port) and indeed I can see that the PC is able to select 4k 60hz, so cables and tv are fine.
Then I enabled stream HDR on the HDR settings in windows.
After that I installed the HEVC codecs from the Microsoft store as suggested in:
https://support.microsoft.com/en-us/help/4040547/windows-10-display-requirements-hdr-video
after all this I still can see 8 bit color depth in my advanced display settings for the 4k external monitor instead of the required 10 bit color depth for HDR.
I know the integrated Intel UHD 620 can stream hdr but all the suggestions didn't work.
what did I do wrong?
I also followed strictly this page:
https://support.microsoft.com/en-us/help/4040255/windows-10-stream-hdr-video
but couldn't see the option "Windows HD Color settings". why isn't it there?
Thanks in advance for your help,
Best Regards,
Luca
