Scaling Adobe apps on Surface Pro 4
My PhotoShop menus and icons appear very tiny making PhotoShop impossible to use . I have installed all updates(windows 10) but nothing worked. Please help me fix my problem.
You can fix this with an external manifest file. It's complicated:
  1. Windows needs to look for an external manifest file. You can do this with  reg file or manually:
REG FILE - copy the test between the dotted lines into notepad and save it as prefer-ext-man.reg
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\SideBySide]
"PreferExternalManifest"=dword:00000001
MANUALLY:
Open regedit and navigate to the registry key:
HKEY_LOCAL_MACHINE > SOFTWARE > Microsoft > Windows > CurrentVersion > SideBySide
Right-click, select NEW > DWORD (32 bit) Value
Type PreferExternalManifest, and then press ENTER.
Right-click PreferExternalManifest, and then click Modify.
Enter Value Data 1 and select Decimal.
Click OK. Exit Registry Editor.
  1. Create a manifest file for your app. Copy the text between the dotted lines and save it with the same name as the executable_name.exe as your program and with a .manifest extenstion. Example, Photoshop should be photoshop.exe.manifest :
<?xml version="1.0" encoding="UTF-8" standalone="yes"?>
<assembly xmlns="urn:schemas-microsoft-com:asm.v1" manifestVersion="1.0" xmlns:asmv3="urn:schemas-microsoft-com:asm.v3">
<trustInfo xmlns="urn:schemas-microsoft-com:asm.v3">
  <security>
    <requestedPrivileges>
      <requestedExecutionLevel
        level="asInvoker"
        uiAccess="false"/>
    </requestedPrivileges>
  </security>
</trustInfo>
<asmv3:application>
  <asmv3:windowsSettings xmlns="http://schemas.microsoft.com/SMI/2005/WindowsSettings">
    <ms_windowsSettings:dpiAware xmlns:ms_windowsSettings="http://schemas.microsoft.com/SMI/2005/WindowsSettings">false</ms_windowsSettings:dpiAware>
  </asmv3:windowsSettings>
</asmv3:application>
</assembly>
  1. SAVE the manifest file in the same directory as the program's executable (you will probably need to acknowledge the UAC prompt to do this).
  2. Restart your computer for this to take effect.
If you want to remove the capability to use external manifest files, you need to reverse the registry edit. Here are the reg file contents
"PreferExternalManifest"=-
you'll need to restart after running the remove external manifest preference.
Last updated December 20, 2021 Views 3,650 Applies to:
