popping sound from speaker
Split from this thread.
I'm experiencing this same issue on my SP4. It's an occasional fairly loud pop. Nearly always happens when the on screen keyboard come up the first time. Happens at other times as well. Even heard it once while it was asleep. Not impressed and not a good sign that this is a carry over from the SP3 it sounds like. If anyone finds a solutions please post!
Hi All,
We released an update on 2/17/2016 that addresses this issue.
We recommend that you install this update to keep your Surface performing its best. You can get updates now by checking Settings> Update & security> Windows Update.
To confirm the updates are installed, check Settings> Update & security> Windows Update> Advanced options> View your update history.
Josh
Last updated September 29, 2019 Views 6,408 Applies to:
