DVD/BLU RAY PLAYER
I have purchased a DVD/BLU RAY external player. It is not playing in my surface pro 4. When it is connected, I am gettimg the following message:-
The last USB yo connected to this computer malfunctioned and windows does not recognise it.
Thanks to help
Surface doesn't have enough power for many USB peripherals like this. You need to try a POWERED USB hub.
Actually  have a Bluray  the is LG and it works fine if you can find the correct software to use with it.
Hi Barb. Many thanks for your reply. I have a surface dock. Direct or 'indirect', it does not work. Regards
can you try a powered hub? I don't think the dock provides any more USB power
than the Surface itself.
Last updated April 11, 2025 Views 357 Applies to:
