What's in the Surface Pro 3 9/29/2015 firmware update
What's in the Surface Pro 3  9/29/2015 firmware update?
Last updated May 18, 2018 Views 443 Applies to:
Hi Clare_Hs
Thank you for asking.
The following updates will be listed as “System Firmware Update –
9/29/2015” within the Windows Update History.
Windows 8.1
  • Surface Pro System Aggregator Firmware update (v3.9.650.0) improves booting time experience and enhances the system reliability while docked.
  • Surface Integration driver update (v2.0.1209.0) ensures when using a custom power plan that the selected plan will not revert to the default balanced power plan when installing a Windows Update.
  • Management Engine Interface driver update (v11.0.0.1157) improves the system stability.
Windows 10
  • Wireless Network Controller and Bluetooth driver update (v15.68.9030.41) improves the wireless network connectivity and stability.
  • Microsoft Docking Station Audio Device driver update (v1.31.35.10) improves audio experience when no external speakers are connected to a Surface Pro 3 Docking Station so that Surface Pro 3 internal speakers are used.
Windows Update will request a restart after installing update.  After restarting, please do another restart (not shutdown) to finish installing the update.
Note:   When Surface updates are provided via the Windows Update service, they are delivered in stages to Surface customers. As a result, not every Surface will receive the update at the same time, but the update will be delivered to all devices. If you have not received the update then please manually check Windows Update later.
**In addition, please check out the Surface Pro 3 update history page for more details on released updates.
If not yet current, the update history page will be updated shortly.
Having trouble downloading or installing from Windows Update?  Please try to manually download and install the update - for instructions see https://www.microsoft.com/surface/en-us/support/performance-and-maintenance/install-software-updates-for-surface.
