On Tue, 8 Jul 2014 19:53:17 +0000, John1F wrote:
|Thanks for reaching out to us. Sorry to hear you are getting inconsistent
and unusual results from wifi on your Surface Pro 3.
|When did this start happening? Can you confirm that your time, timezone and
date are accurate? Restart Surface and your router, try connecting again.
|Does this behavior persist across different networks? Are you seeing speeds
from Surface to the router, or is this out to the internet as well?
|Have you tried logging in with a different Microsoft account to try accessing
the Store?
|Are there any pending updates?
|Desktop> Swipe for Charms> Settings> Control panel> Windows update> check for
updates> install
|Remember to restart between layers of updates, and twice after the last
update installs.
|Let us know what is happening.
This is the well known issue discussed ad nauseam at
I can easily duplicate the issue with the Windows Store on battery power/resume
from connected standby. ONLY happens on battery power.
Also, Microsoft is throttling the firmware updates that may (or may not)
provide relief. I've been checking manually after installing the regular updates
at 1pm EDT for nearly 6 hours and the firmware has not appeared.
Barb's Connected World Blog Reader Windows 8 App -
Windows and Surface Community Reader Windows 8 App
