Surface Pro 3 LGC Battery Degradation
Split from this thread.
It was suggested that I open a new thread for this issue that I am having.
Since the Win 10 Anniversary update, I was not able to turn on my Surface Pro 3 i7 512GB with LGC LGC Battery without having it plugged in with the power supply or docking (I own a total of Three Surface Pro 3 Docks at home and 2 offices). It always said "82%, Plugged in, Not Charging", and would always instantly turn off once I pulled off the power supply tab.
I had spoke with a Technical Agent online, had my Pro 3 remote accessed, did all the proposed solutions, and even had a call from Bellevue, WA (I live in Hong Kong) before I found out that it was a software issue as stated by Microsoft.
With Auto Update turned on, I was notified that I should restart my Pro 3 this morning while I was on the docking station. I was happy that this issue was going to be resolved, but now I am disappointed that this firmware update did nothing for my Pro 3.
I'm hoping that someone out there has some suggestions.
Thank You.
Got a reply from MS:
That’s definitely a different problem from what we saw with the Simplo batteries.  I’ll send it back up to the engineering team.
I also have the issue with LGC battery.
Before 8/29 update, my SP3 has battery issue, once unplugged SP3 will shutdown within 20 seconds because of battery. After 8/29 firmware update, the problem is still there. Here is the battery report, only 144mWh.
Your issue does look like the SIMPLO one to me. I've alerted an internal contact. Can you post the rest of the battery report showing the history please?
I've got email from my contact already. Can you EMAIL me and give me
1. serial number of your surface
2. apprx date of purchase
***Personal information deleted by the moderator. Please see the Microsoft Community Frequently Asked Questions for more information on how you can protect your privacy.***
Thanks, Barb. I sent you the email.
Already forwarded to my contact, he acknowledged receiving it.
Thank You, I hope that this can eventually be solved because all the methods we tried had no effect. The only suggestion that I didn't try was Resetting my surface, but I doubt that it would change anything, other than that I would lose all my data.
for you folks with the 82%/97% plugged in, not charging. Microsoft is working on specific steps to try (involving removing the battery driver - not deleting it - and restarting to let it reinstall) to resolve this.
Should be a few hours and I'll post these as soon as I get them. It's 7am in Redmond so they are just waking up there.
même probleme
Battery report
COMPUTER NAME DESKTOP-JB70L34
SYSTEM PRODUCT NAME Microsoft Corporation Surface Pro 3
BIOS 3.11.1550 06/30/2016
OS BUILD 14393.82.amd64fre.rs1_release.160805-1735
PLATFORM ROLE Slate
CONNECTED STANDBY Supported
REPORT TIME 2016-08-3118:06:31
Installed batteries
Information about each currently installed battery
NAME X883815
MANUFACTURER LGC-LGC
SERIAL NUMBER 1219109892
CHEMISTRY LION
DESIGN CAPACITY mWh
FULL CHARGE CAPACITY mWh
CYCLE COUNT 26
Recent usage
Power states over the last 3 days
2016-08-3023:13:05 Active AC 99 % mWh
23:19:24 Active Battery 100 % mWh
23:25:00 Suspended 100 % mWh
23:28:56 Active Battery 100 % mWh
23:30:46 Connected standby Battery 100 % mWh
23:30:47 Suspended 100 % mWh
2016-08-3100:16:47 Connected standby Battery 100 % mWh
00:16:47 Active Battery 100 % mWh
00:24:30 Connected standby Battery 94 % mWh
00:25:28 Active Battery 94 % mWh
00:45:04 Suspended 87 % mWh
00:47:34 Active Battery 87 % mWh
00:49:14 Connected standby Battery 86 % mWh
00:49:15 Active Battery 86 % mWh
02:47:59 Suspended 48 % mWh
08:02:38 Active AC 99 % mWh
2016-08-3023:08:00 Suspended 99 % mWh
2016-08-3102:49:55 Active Battery 47 % mWh
02:56:59 Connected standby Battery 43 % mWh
02:57:00 Suspended 43 % mWh
12:56:20 Active Battery 43 % mWh
13:06:10 Connected standby Battery 38 % mWh
13:06:11 Suspended 38 % mWh
17:39:44 Connected standby Battery 37 % mWh
17:39:44 Active Battery 37 % mWh
18:05:53 Report generated Battery 21 % mWh
Battery usage
Battery drains over the last 3 days
2016-08-3023:19:24 Active 0:05:35 - -
23:28:56 Active 0:01:49 - -
23:30:46 Connected standby 0:00:01 - -
2016-08-3100:16:47 Connected standby 0:00:00 - -
00:16:47 Active 0:07:42 6 % mWh
00:24:30 Connected standby 0:00:58 - mWh
00:25:28 Active 0:19:35 6 % mWh
00:47:34 Active 0:01:40 1 % mWh
00:49:14 Connected standby 0:00:01 - -
00:49:15 Active 1:58:43 37 % mWh
2016-08-3102:49:55 Active 0:07:04 4 % mWh
02:56:59 Connected standby 0:00:00 - -
12:56:20 Active 0:09:49 5 % mWh
13:06:10 Connected standby 0:00:01 - -
17:39:44 Connected standby 0:00:00 - -
17:39:44 Active 0:26:08 16 % mWh
Usage history
History of system usage on AC and battery
2016-08-30 0:07:24 0:00:01 0:06:18 -
Battery capacity history
Charge capacity history of the system's batteries
2016-08-30 mWh mWh
Battery life estimates
Battery life estimates based on observed drains
2016-08-30 - - - -
Current estimate of battery life based on all observed drains since OS install
Since OS install - - - -
Are you docked or undocked? If you unplug, does it shut down?
Last updated April 5, 2021 Views 1,796 Applies to:
