Hello and welcome to the refreshed Surface support community! If you visit us regularly, you will notice that we’ve made some changes to make our community easier to navigate. For example, you can now find all of our Surface Laptop products under the Surface Laptop option in the Products menu.
We made these changes to help you find the answers you need as fast as possible. Thanks for being a Microsoft Surface customer!
I had an external dvd rw drive that didnt work with just the power that comes from the usb port. Fortunately the dvd drive came with a kind of "Y" usb cable. One side goes to the surface usb port and i connect the other to an Ipad battery charger. It needs
to be an ipad battery charger because is 2.1 amps....the iphone battery charger is 1 amp only. I did that and everything worked fine. Check if your drive came with something like that.
You do not have to use an iPad charger. The power supply that comes with the Surface Pro 3 has a 1A USB port. This is enough to run almost any external peripheral including hard drives and external dvd drives designed to run off USB.
It has been suggested that you get a Y-cable usb cable. I have one too for an external monitor that runs off USB3 only. Plug the power only end of the y-cable into the usb port on the Surface Pro 3 power supply.
I forgot that the sp3 power supply have an available usb port for charging a device. Check if that work..if it dont try an ipad charger that the output is 2.1 amps.
Last updated October 8, 2020
Views 897
Applies to:
