How Do I Do The Equivalent Of Making Subst Mapping Permanent?
Windows 8.1 Pro
Surface Pro 2
I am trying to replace laptops with Surface Pro 2.  The laptops normally have C; and a 407 GB V: partions which the applications expect.  Unfortunately, The C: partition of my Surface Pro 2 cannot be shrunk lower than 241 GB which does not leave enough room for a 407 GB V: partition.
I thought I could get around the problem by creating a folder C:\V and using Subst V: C:\V
This works if I enter the Subst command after each login.  It does not persist across logins.
I then tried using a .reg file:
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager\DOS Devices]
"V:"="\\?\\C:\\V"
Note: The double back slashes become single ones in the registry.
This created a V: drive but with a ?.  When I tried to open it I got: V:\ is not accessible.  The filename, directory name, or volume label syntax is incorrect.
I also tried:
"V:"="C:\\V"
Same results as above.
[HKEY_CURRENT_USER\Software\Microsoft\Windows\Run]
"V Drive"="subst V: C:\\V"
This did nothing.
I can't use Net Use to do the mapping because that requires setting up a share.
Is there anyway to get the equivalent of: Subst V: C:\V
but persistent.
Edit:
I should learn to type.  The correct syntax is:
"V:"="\\??\\C:\\V"
Note the double ?.
That works.
Last updated May 28, 2019 Views 8,007 Applies to:
Greetings, saberman
Thank you for reaching out to us, I understand your concern,
I recommend you contact the Microsoft MSDN or Enterprise for
more detail information and additional helps.
Thank you
Best regard.
