System Firmware Update - 12/10/13 fails to install
Got the updates on todays patch Tuesday, but the firmware update failed to load.  Rechecking for an update does not give the opportunity to try and reinstall.
Anyone else having this problem?  I do notice that my telemetry driver is now loaded. so not sure what is going on here.
Josh,
We are working through the holidays to deliver a fix for the small number of customers that have experience decreased battery life and booting/sleeping problems as a result of the December update.  We took the update down to prevent additional customers from ending up in this state. All hardware failures, none of which are known to be caused by the December update, are being handled promptly through our warranty exchange policy.
The UEFI firmware that we released in the December update prevents some devices from entering sleep mode (and other low power states) properly during periods of inactivity. In order to release an updated version of the UEFI firmware we need to test the new version with the other drivers in the set to make sure we are not releasing yet another unknown state to customer machines. We certainly feel your pain and assure you that we are doing everything possible to make this right, as quickly as we can.
Thank you,
Tim
Microsoft Surface Team
Greetings all,
We understand that the February Firmware Update has fixed the Battery gauge issue and the Firmware showing as failed. However we can see that there are some customers who are still experiencing issues with their Surface Pro 2 going into Sleep mode and Hibernate.
So we can better track those particular issues, we have decided to close this thread off. We encourage you to create a thread related to your Surface Pro 2 not going to sleep or not going into Hibernate. Please give as much detail as possible to your scenario.
We understand that the February Firmware update did not resolve the issue with waking from Sleep or Hibernate, as it was not intended to fix that particular issue. We are continuing to work to deliver a high quality solution. More updates will become available as this effort progresses.
Thank you for posting,
Steven B
Last updated January 3, 2020 Views 41,905 Applies to:
