How do I add a keyboard to my Surface Pro computer
Have extention USB ports on my Surface Pro2 & want to add an external keyboard. Can this be done? How? Also would like to add an external monitor, canthis be done? How?
Last updated August 2, 2019 Views 142 Applies to:
Hi Jill,
You can connect up to two external monitors to your Surface Pro 2 by using compatible cables and adapters. You can visit this link to learn more about connecting external displays to your Surface.
Furthermore, if you've already tried connecting a USB keyboard to your Surface and it didn't work, you might want to follow the steps posted by SamCooke on this thread, see if it helps.
We hope this works, and let us know if you have any additional concerns.
Regards.
