Would dual booting the Surface Pro void its warranty?
I'm used to using Windows 8 Pro and Ubuntu 12.04 LTS in tandem. Does the Surface Pro address dual-booting in its warranty? If not, does anyone know if this would pose any issues on a Surface Pro?
Greetings,
To add to what Jordana listed, if you remove the factory image, that Microsoft has provided and add your own image, even Windows 8 Pro (non-OEM), you have lost support for the Surface.
So long as you dual boot and keep the factory OEM version of Windows 8 Pro, you're good to go.
Thank you for posting,
Steven B
Greetings BS661,
Microsoft will only support the preinstalled software, as per the warranty.
Technical support: Provides help and technical support on preinstalled software for the first 90 days after purchase.
Steven B
Last updated November 12, 2020 Views 16,896 Applies to:
