Surface Pro error: File:\BCD Error code: 0xc0000034
Anyone know how to fix this problem; my screen shows:
Recovery Your PC needs to be repaired
The boot configuration Data file is missing some required information
 You’ll need to use the recovery tools on your installation media. If you don’t have any installation media (like a disc or USB device), contact your system administrator or PC manufacturer.   Press the Windows Key for UEFI Firmware Settings.
If you go to the UEFI- it displays options which revert back to the above screen.
Last updated October 22, 2019 Views 27,821 Applies to:
Have you tried Safe Mode? Hold Shift+F8 (the Gear key nex to Home) while turning on the Surface Pro to see if you can get into Safe Mode.
I sometimes write about tech here:
177 people were helped by this reply
