Surface Book 2 GPU Driver disappears randomly after May 2019 update
Hi, just recently installed the Windows 10 May update on my Surface Book 2. Now the GPU disappears randomly while in use. The only solution is to reboot the Surface Book 2, or go into the device manager and initiate a scan for the GPU to come back again. It has Nvidia Gforce GTX 1050 version 23.21.13.9140
Are there any plans for Microsoft to release an updated driver to fix this bug?
Last updated April 2, 2020 Views 6,601 Applies to:
Thank you for reporting the issue. A fix is available through Windows Update.
For more information, please visit our Surface Book 2 Update History page.
Eddy
updated: 10/11/2019
There are some updates that were pushed to PRODUCTION today https://support.microsoft.com/en-us/help/4055398/surface-book-2-update-history You do NOT need to join Insiders to get these.
October 2019 updates
The following updates are available for all Surface Book 2 devices running Windows 10 April 2018 Update, version 1803 or greater:
Windows Update History Name
Device Manager Name
Surface – System – 1.75.139.0
Surface Base 2 Firmware Update – Firmware
  • 1.75.139.0 improves battery stability.
Surface – Firmware – 182.1004.139.0
Surface System Aggregator – Firmware
  • 182.1004.139.0 resolves an issue where the CPU will throttle down to .4GHz, and improves battery stability.
Surface – Firmware – 389.2837.768.0
Surface UEFI – Firmware
  • 389.2837.768.0 resolves an issue where the display adapter disappears from Device Manager.
