How to force NVidia 1060 on Surface Book 2
Hi.....  proud new owner of a 15" Surface Book 2!
I cannot find where to tell the PC which GPU to use for an app.   I had owned the previous Surface Book and there was an NVidia Control panel thatgave you all kinds of control over that.
The new Surface Book 2 doesn't have that installed on it and it seems that it's stuck using the crappy Intel Pro 620 GPU on every piece of software.  I haven't modified ANYTHING since I unboxed it last night (in other words, I haven't screwed any drivers or anything up).   If I look under Device Manager, it shows both the Intel 620 and the NVidia 1060 as graphics adapters.
I'm sure this is something very simple but thanks for helping!
The NVIDIA Control Panel does not appear when pressing Start and typing because it is not in the list of apps in the Start menu.
To open it, go to: Control Panel, Hardware and Sound, NVIDIA Control Panel.
70 people found this reply helpful
Yes
No
try downloading the latest Surface Book firmware here:
https://www.microsoft.com/en-us/download/details.aspx?id=49497
go to your "system information" find "version" and download the firmware closest to that number.....
if all else fail...MS can "Fresh Start" your laptop.  Unfortunately, thats what I had to do but everything is working properly after that. Make sure you back up everything first.
Yes
No
Last updated September 4, 2021 Views 41,863 Applies to:
