Surface Book Cameras exhibiting green tint and slow frame rate when used by desktop applications for Video Conferencing.
When I attempt to use desktop applications for video conferencing such as Zoom Meetings or BlueJeans Video Conferencing, the camera shows a green tint and the frame rate is super slow. This is also true of the Microsoft Camera Rear. Same behavior is seen after disabling Microsoft IR Camera from device manager.
Using the NVIDIA High-Performance Graphics processor for those applications cause them to crash. So I have those applications set to default to using the "Integrated Graphics" via the NVIDIA Control Panel. So the applications seem to be having issues with the Intel HD Graphics 520.
Intel HD Graphics driver version is 20.19.15.4463
Microsoft Camera Front driver version is 30.15063.10999.4731
This behavior is seen on multiple (30+) machines.
We appreciate the information. We suggest you look into disabling hardware acceleration to see if there will be changes. Doing this may keep the desktop applications from crashing as the setup will utilize the CPU instead of your graphics card alone. We suggest you seek advanced assistance in performing this by sharing your post in TechNet. The IT Pro audience in the said forum will also be able to give you other options to resolve the problem. Go here to get advanced suggestions from TechNet users.
We're here if you have other concerns.
Last updated October 14, 2020 Views 2,546 Applies to:
