Surface Pro 3 pen battery life?
Hello, I have surface pro 3 and I was wondering how long the battery usually lasts for the pen?
of course I'm asking for both the bluetooth(319x2 button cells) and the AAAA x1 battery for the pen itself.
usage time would be around 5-7hours per day(for using onenote and drawing applications)
thank you
Hi Dagliortz,
Thank you for bringing this question to us. I understand you have a question about the pen battery.
Is this the first time you have to replace the battery? Or, Has this consistently happened for several weeks? If you have been replacing the battery weekly for a while, please reach out to our assisted support for further assistance.
Kind Regards,
Clare
Yes
No
See the answer at
one per week seems abnormal and you should reach out to get the pen replaced.
Yes
No
Last updated April 5, 2021 Views 37,034 Applies to:
