How do i tell what surface pro version do i have. I see 1724 on the back of the screen
Ron,
There are a few ways to tell, for any Surface Device:
  1. Use the Surface app. That will tell you. If you don't have this installed, you can get it from the Microsoft Store.
  2. Visit the Microsoft Device service and repair site to register your device serial number. See Find the serial number on Surface if you are unsure where this is on your device.
  3. If you are unable to get online, use the System Information app to view your system info. From Search, type system and then select System Information from the list of results.
Hope this answers your question. If it does, please DO mark as answer.
144 people found this reply helpful
Last updated June 7, 2021 Views 77,046 Applies to:
