Surface Pro - No Wireless Networks
(NOW RESOLVED)
I've had my Surface Pro for about a week and haven't had any problems with network connectivitiy until a few hours ago. It is not picking up any wireless networks although it is clearly in range and the network is clearly working on other machines.
When I troubleshoot the problem, it says that there is a problem with the driver for the Ethernet adapter, though the Pro doesn't have an ethernet jack.
Airplane mode is turned off.
When I go to Network and Sharing Center and click Set Up A Network, both options "Connect to the Internet" and "Set up a new network" do not work. The latter brings up a box that asks me to "Choose the wireless router or access point you want to configure" and although I wait for longer than 90 seconds, nothing appears.
EDIT: Okay, I think I found the problem. In my PC Settings in the Wireless tab, the "Wireless devices" and "Bluetooth" switch is turned off. The problem now is that when I try to turn that on, it'll go through a little loading period and flip back off. I'm not sure how to turn this on for good.
EDIT 2: I fixed this problem by opening the Device Manager, expanding the Network Adapters tab, double clicking the wireless adapter and disabling then enabling it.
(NOW RESOLVED)
Followed Instruction @ Edit2:
At device manager found Marvell Avastar Wireless Composite Device.  Disable(d) it. Did not see an Enable option.   So, I chose update driver.  That worked.
Gracias.
46 people found this reply helpful
Hello KerryBarret and everyone,
I'm glad to jump and help. Please take a look at this article.
Let us know.
Cheers,
Reagan_L
Last updated April 5, 2021 Views 52,818 Applies to:
