Surface Book 2 Heating Issue
I was wondering if this these types of numbers were ok for the surface book 2 15inch.  When touching he surface book the thing is extremely hot.
Just to clarify, were you able to perform the steps on the link provided above?
Surface devices are equipped with an overheat protection. The device complies with the user accessible surface temperature limits defined by the International Standard for Safety of Information Technology Equipment (IEC 60950-1).
In the event that your Surface reaches a certain point of temperature, a warning icon should appear. If not, it means your device is still good and the temperature is within range.
For more information and troubleshooting steps, you may want to check Edjay Rust's post form this link and check if it helps.
Get back to us with the outcome so we can help you out further.
Regards.
Last updated April 19, 2021 Views 9,161 Applies to:
