Will Surface pro X keyboard work with Surface pro 9
Hi Team,
I have the Surface pro x keyboard with me, Please do advise if the keyboard will work with Surface pro 9. I have already placed order for surface pro 9.
The surface pro X that I had fell from the table and broke.
Thank you for reaching Microsoft Community. I understand that you would like to know if the typecover that you have from your Surface Pro X that broke would also work on a Surface Pro 9.
To answer your question: Yes, the typecover from the Surface Pro X should work or compatible with the Surface Pro 9. The Surface Pro 9 uses the same typecover connectors used on the Surface Pro X. As an example, this Surface Pro Signature Keyboard (Buy Surface Pro Signature Keyboard - Cover with Backlit Keys | Microsoft Store) is compatible with the Surface Pro X, Surface Pro 9 and Surface Pro 8 (see Techspecs section).
Kind regards, Marrion
We haven't heard from you, so we assume that your issue has already been addressed. We will not be monitoring this thread moving forward so, if you need further assistance, please create a new thread to discuss these concerns by clicking this link: Create a new question or start a discussion (microsoft.com)
Thank you for understanding.
Last updated September 30, 2024
Views 1,611
Applies to:
