wifi issues
I had an issue this morning where Surface couldn't find any wifi networks (when 5 were in the area) and it was connected the previous night. I solved this issue by searching windows rt for Network. Open Network Connections, find the wifi device and then disable this connection. After a minute - I re-enabled the connection and then it started to work.
Just wanted to share my experience if anyone runs into the same issue. Thanks!
Nate
Greetings everyone,
Thank you for your continued interest, feedback and assistance in investigating the Limited WiFi issue on the Surface.
Not all limited connectivity scenarios have solutions that can be controlled by the Wi-Fi drivers of a given device. Limited connectivity scenarios result from a complex interaction of device Wi-Fi drivers, access point firmware, access point configuration, and other environmental factors.
If following the steps in the provided links below fail to resolve your Wi-Fi issue I encourage you to create a new thread.
Thank you for posting,
Steven B
Greetings all,
We are working on a solution for the Limited WiFi issue. Please refer to the following thread for potential workarounds while we are working on the WiFi issue:
http://answers.microsoft.com/thread/c593dff8-61b3-496c-b8f2-f9deb3e4b35e
Steven B
30 people found this reply helpful
Last updated April 5, 2021 Views 76,457 Applies to:
