What external CD/DVD/Blu-ray player works with Surface Pro using Windows 10?
Surface does not have enough power over USB for many peripherals. You DO need to
try a POWERED USB hub with the new drive. This has resolved this issue for many
others.
·Was this reply helpful?
Also try uninstalling and reinstalling the USB controller drivers:
Uninstall and Reinstall all the USB Controllers
1. Disconnect the USB CD/DVD drive from your Surface and remove any micro SD
card in the slot.
2. Open Device Manager
<https://support.microsoft.com/help/4026149/windows-open-device-manager>.
3. Expand *Universal Serial Bus Controllers* .
4. Right-click on every driver under the *Universal Serial Bus Controllers*
listing, and then click *Uninstall* to remove them one at a time.
5. Restart the device so that Windows reinstalls the USB controller drivers
automatically.
6. Plug the USB peripherals in again and check if that resolves the issue.
Last updated September 19, 2024 Views 3,574 Applies to:
