Water on surface pro
about 3 weeks ago my computer gat wet, can you help me fix it?
Hello, have you tried turning it on? Does it work and charge?
Yes it turns one and charger seems to be working.
If it got wet, and you allowed it to dry before turning it back on, you should be in good shape if everything works on it.
There are lines across the screen. Mouse does not work
After water spilled on the pc, i did not dry it.
Mouse does not wok,
lines acroos the screen and it does turn on. Can someone give me advice?
i dont hav the pen and i am having problems finding the curser arrow.
any suggestions?
Hi Rose,
Sorry to learn about this. There is nothing you can do but get service for your Surface https://support.microsoft.com/en-us/help/402352...
Andrew N.
Hi Rose,
From your previous message I've learned that you spilled water on your Surface. I would still recommend getting service for your device https://support.microsoft.com/en-us/help/402352...
Andrew N.
I did turn it om... to see if it was working. Worked ok then everything went wild.
Hi, i hope you're doing good today.
Refer to this thread and let me know if it helps.
https://answers.microsoft.com/en-us/surface/for...
Regards.
Last updated March 29, 2025 Views 4,116 Applies to:
