Surface Pro Type Cover + Scroll Lock shortcut ???
I don't understand how, for 10+ years no-one has been able to answer this
Every so often I accidentally toggle Scroll Lock using my Surface Pro Type Cover
Excel cell selector suddenly refuses to respond to the arrow keys, and the whole page moves instead
The Type Cover keyboard does not have a Scroll Lock key and, for the life of me, I've been unable to find any reference to the shortcut I accidentally tripped - needless to say impossible to replicate
The only solution ever offered to disable Scroll Lock is to use the accessibility On Screen Keyboard
Surface Pro: how do you turn off Scroll Lock? - Microsoft Community
Desperate request to someone at Microsoft - Please, please, PLEASE, put me out of my bafflement and let us know what the hidden shortcut key combination is???
Hi Remy!
Thanks for reaching Microsoft Community. We're here to help and let's work on this together.
With your query, I apologize for the inconvenience you are experiencing. The Surface Pro Type Cover does not have a dedicated Scroll Lock key. However, you can try using the Fn key and the Caps Lock key together to toggle Scroll Lock on and off. Alternatively, you can try using the On-Screen Keyboard to disable Scroll Lock. To do this, go to Start > Settings > Ease of Access > Keyboard > Use the On-Screen Keyboard. Once the On-Screen Keyboard is open, click on the ScrLk button to disable Scroll Lock.
I hope this helps!
RodelioP.
Thanks, but we've seen these responses before
[Fn] + [CAPS Lock] does nothing
It seems the illusive Type Cover shortcuts eludes us still
the only solution is to invoke the On-Screen Keyboard
Hi Remy!
Thanks for getting back to us and apologies for the delayed response as I have been out of office.
We truly appreciate your cooperation on this, with regards to that, I would highly suggest you submit a feedback so that our Microsoft engineers can check on this. See through this link Send feedback to Microsoft with the Feedback Hub app - Microsoft Support on how to post a feedback.
Thanks again for choosing Microsoft!
RodelioP.
I had the same problem and was able to find elsewhere that you can activate the "on-screen keyboard" which has the Scroll-Lock button that you can push to turn off. Activate this "on-screen keyboard" by pushing CTRL + Windows + O. You'll see the ScrLk key available for you to push.
Last updated April 21, 2025 Views 2,563 Applies to:
