surface pro SSD problem
I try to repair with image recovery but not work .
after this use the disk part command and show disk with zero byte.
recover not work
 disk0 size 0b
 detail disk
 in the easeus partition
I cant make any partition in the both program
Hi Hadi,
Based on the screenshots you have sent, this maybe an issue with your hard drive not being detected by your device or worse, a possible hardware issue.
In order for us to confirm that, may we know if you can still login to Windows?  If not, there is no way, then we may opt to boot from the UEFI environment of your device.  In order to do that, simply follow the steps provided at this link.
Once you're in the UEFI environment, try to see if there is an icon like this  at the upper right of the screen.  If there is, that means that there is a possibility that your Surface is not detecting the hard disk.  This would also explain why in the screenshots you sent, it is not detecting the total capacity of your hard disk or it is showing 0 bytes.
If this would be the case, the only way to resolve it is to bring it to the nearest Microsoft Store or contact our Microsoft Support via phone through this link so they can process a replacement for it.
hi johnP
you say right but i no access to microsoft store ..so i found one way to setup windows 10 to usb flash drive and install all driver surface pro 2017  and for me enough.
thanks.
Last updated July 12, 2020 Views 4,684 Applies to:
