Surface Pro 8 wakes up from sleep when it shouldn't
This is extremely frustrating.
I put my surface pro in my backpack fully charged and when I get it back the battery has been drained to 50%.
The light of the screen even wakes me up in the middle of the night for no reason.
The Power Management tab that allowed us previously to disable "Allow This Device to Wake the Computer" is hard to find in the Device Manager and it seems to have no effect.
EDIT: It doesn't seem to wake up alone anymore, but there is no way to disable the signature keyboard lid, keyboard and Bluetooth mouse waking it up.
***Post moved by the moderator to the appropriate forum category.***
Hi Phemios,
Thank you for reaching Microsoft Community. I'm sorry to hear about the power issues that you are experiencing on your Surface Pro 8.
The Surface Pro 8 uses the Surface Unified Extensible Firmware Interface (UEFI) instead of the Legacy BIOS. See: How to use Surface UEFI (microsoft.com).
When you left the device on your backpack, was it fully Shutdown or it was just on Sleep mode?
The Surface should not turn on by itself with just a move of the mouse when it is on Shutdown. However, it is possible to wake the Surface by moving the touchpad or by pressing a key when it is in Sleep mode. Try checking the Power Management tab on the Bluetooth Low Energy GATT compliant HID device driver under Human Interface devices in Device Manager.
Please try checking also in Control Panel > Hardware and sound > Power options. Click Change advanced power settings option. On the Advanced Power Options window, kindly take a screenshot of it and share it with us here.
For now, kindly run these steps on your Surface Pro 8 then observe if the issue persist:
1: Run Surface Diagnostic Toolkit
See: Fix common Surface problems using the Surface Diagnostic Toolkit (microsoft.com)
2: Check for Windows Update
Go to Windows Settings > Update & Security and select Check for updates
Make sure all updates need are installed including Optional updates
3: Update drivers and firmware
Check what is the current OS Build of your Windows version by going to Settings > System > About
Go to Download driver and firmware for Surface, choose Surface Pro
Then click the link next to Surface Pro 8 then click Download on the next page.
Choose the .msi file that matches your current OS Build and click Next.
After downloading, run and install the .msi then Restart.
4: Run System File Checker Tool
See: Using System File Checker in Windows (microsoft.com)
Kind regards,
Marrion
Hi Phemios,
We have noticed that you haven’t replied to our first response yet. We would like to know if you still need some assistance on the concern raised. If yes, please reply back for us to further assist you.
Hope to hear from you.
Kind regards,
Marrion
Hi Phemios,
We still have not received any response from you since our last follow up message. In case you need further assistance on the concern raised, please proceed in creating a new post.
Thank you for spending time here in the Community.
Kind regards,
Marrion
Thank you for your answer. The system is up to date and I have downloaded the last firmware for the Surface Pro 8 and Windows 10.
Even with the settings shown in the screenshots below, the keyboard, the mouse and the keyboard cover (open/close) wake up the computer.
The mouse is not critical because I can switch it off, the keyboard can press a key accidentally very easily and a slight misalignment of the keyboard cover wakes up the computer (I imagine that this is why it always wakes up in my backpack). I really need to disable the wake up function for the latter two ones (which belong to the signature keyboard).
Here you have my settings in the Devices Manager:
And my Advanced Power settings (In my previous computer I could see all the devices here but in the Surface Pro it only shows me Desktop, Sleep, Display and Battery):
Hi Phemios,
Thank you for the response and details provided. Please try first to reset all power plans of the device by running the command below on an elevated Command Prompt (Admin):
powercfg -restoredefaultschemes
After running the command, restart the Surface then proceed to these steps below:
1: Disable this device to wake the computer
Open Device Manager
Navigate to the mouse and keyboard drivers and disable the setting
2: Disable wake timers
Go to the Power Options window
Expand Sleep and check if Allow wake timers is now listed
If yes, set it to Disable
After doing those steps please check if still the device wakes up on its own in the middle of the night. If yes, may I know what are the accessories or peripherals connected to the device?
Kind regards,
Marrion
Hi Phemios,
We have noticed that you haven’t replied to our last response. We would like to know if you still need some assistance on the concern raised. If yes, please reply back for us to further assist you.
Kind regards,
Marrion
Hi Phemios,
Kind regards,
Marrion
Sorry for the delay. Thank you for your reply but this doesn't help. I'm shutting down my surface to avoid losing sleep at night and to avoid losing battery every time that I put it in my bag.
I ran: "powercfg -restoredefaultschemes" and restarted my surface,
Then I went to "Device Manager" and disabled the "allow this device to wake the computer" on the mouse (Bluetooth Logitech M650). I had already disabled it. It has no effect. I put the surface to sleep and either a mouse move or a click wakes it up again. Below there is a screenshot of it.
In the Device Manager, none of the Keyboards shown above had a "Power Management" tab so I couldn't disable anything. Also note that not only the keyboard keys or touchpad wake the surface up but opening or slightly moving the lid when it is closed also wakes the surface up. For reference, I have the surface standard Signature Keyboard with the pen.
I can't find a "Power Options" window so I couldn't do that.
I don't have anything else connected to the Surface other than the mouse and the keyboard via Bluetooth.
Hi Phemios,
Thank you for ;the response and updates. Apologies for the delay in getting back also.
Please try going to Windows Settings > Bluetooth & devices > USB. Enable the USB Battery Saver option. After doing this, check if still the device wakes up by keyboard key press or a mouse movement.
Kind regards,
Marrion
Hi Phemios,
I would like to check if you were able to try the step provided on my last response? Please let us know how it goes.
Kind regards,
Marrion
Last updated June 1, 2024 Views 1,779 Applies to:
