I have had my Surface Pro 8 for just over a year, and for the last 3 or 4 weeks or so, suddenly the screen will just go multi coloured lines, as per the photo attached.
There is no way to get the normal screen back apart from shutting down the laptop and then re-starting.
There doesn;t seem be any reason it does this, and I have tried to recreate when it does, but that doesn;t work. Also, some times it happens after 10 mins of login, and then sometimes 1 hour.
I have the latest Windows Updates. Would this be a hardware error, or maybe device driver related?
Any advice would be helpful.
Regards
Graham.
