how can i tell what is health condition of my pro 8 battery in %?
May 10, 2024
April 9, 2024
Click here to learn more 💡
surface pro 8 battery health
Press Windows key + X, then (depends on your version of Windows) click Windows PowerShell(Admin) or Command Prompt (Admin),
OR (Windows 11)
right-click the Start menu button and select Windows Terminal or Windows Terminal (Admin)
OR search for Windows Terminal or Powershell and select Run as Administrator
and then type
powercfg /batteryreport
then press the Enter key. The battery report will be saved under C:\Windows\System32 as battery-report.html
Upload this report to your OneDrive and share a link, then reply to this message and paste in the link. Please upload the HTML file and do not convert to another format.
followed all steps but no battery-report.html at C:\Windows\System32.
using win 11.
that doesn't tell me anything useful. Please upload the entire report following the instructions above.
Hi Barb,
My apologies for the delay in replying.
It seems that I am unable to upload the file to the message (size 3.3MB).
Is there another way to transfer this file to you?
the following picture is after 15 minutes of uploading...
Do not save as PDF. Upload to OneDrive.
OR (Windows 11)
and then type
still waiting...
Last updated February 6, 2024 Views 81 Applies to:
