May 10, 2024
April 9, 2024
Click here to learn more 💡
Surface Pro 6 SIM Card Slot
·Was this reply helpful?
22 people found this reply helpful
I have a Surface Pro 6 and the Micro SIM slot is located pretty much where the SP5 slot is located. Lift the flap on the back, and you will see the slot. I just installed a Samsung 512 GB micro SIM card, and it fit into the slot, and worked perfectly. You insert the card face up.
I too found slot - inserted 128 GB Micro (face up) - it not work - I guess as it not yet formatted.
Any other suggestions appreciated.
Tocar
with the label side up, when you insert it does it "click" into place and do you
hear the "ding" plug and play sound when the Surface is at the desktop?
Last updated May 9, 2024 Views 17,722 Applies to:
