This has been going on for a while. Generally, it has to connect to the wifi and then it works for a while, for streaming videos and such, but then when actively browsing, the connection gets lost.
What we already tried was to update the drivers for the network controller, or roll back an update, reinstall the drivers. All of that.
As it is currently, in order for it to work, I have to go to the Network controller properties, select "update driver" and then it works for a while.
Under the events it lists:
Device not migrated
Device configured
Device installed
Device started
Also, there was the suspicion that it is due to the power saving settings in the device, however, there is no power management tab to be found here.
Would a complete system restore maybe solve the issue?
Are there any other simple miracle cures that we might have overlooked?
Many thanks in advance.
