Hi Jack,
Thank you for bringing this up. Based on the information you’ve provided, it is possible that this issue is software or hardware driven.
Just to set proper expectations, we may go through a series of troubleshooting steps in order to resolve your concern. By the way, we’d like to know if you’ve made any recent changes in your device prior to the issue. Also, have you tried any troubleshooting
steps as an attempt to resolve the issue? If yes, kindly tell us the troubleshooting steps you have done.
In the meantime, we recommend that you check the connections and clean the connector on the power supply. Dirt or debris on the connector’s pins could be preventing a power connection. To do this, kindly follow these steps:
1. Unplug the power supply from the wall.
2. Clean the pins on the connector with a pencil eraser.
3. Clean the pins on the connector with a cotton swab wet with rubbing alcohol.
4. After you are done cleaning the pins, make sure all the pins on the connector are dry, plug the power supply into the wall, and then plug the connector back into your Surface.
If the issue remains the same, you can remove and reinstall the battery driver. Here’s how:
1. From Device Manager, expand the Batteries category.
2. Double-tap or double-click Microsoft Surface ACPI-Compliant Control Method Battery, select the
Driver tab, and select Uninstall > OK.
Note: For Surface Book devices there will be two battery drivers to uninstall.
3. From the Action menu, select Scan for hardware changes.
If it is still the same, we suggest that you
run the Surface
Diagnostic Toolkit on your device. This toolkit will install
all the available updates for your device, check for any errors, and fix them. You may refer to the article for more information and step-by-step guide on how to run the Surface Diagnostic Toolkit. Then, observe if the issue persists.
If you continue to have this issue even after performing the above steps, please reply to this thread. The system will notify us so we can get back to you and provide you more answers.
Many thanks.
